E10 fuel in the UK
  • E10 fuel in the UK
    So what are we to do when E10 fuel is introduced in the UK? Does this mean we have to use the super unleaded, or can we get our cars to run on the E10 fuel?
    The Escos isn't listed on the government check site, though I'd be surprised if it really was happy on E10. However, super unleaded is going to still be E5, and I hae always run my car on that anyway (Shell v-Power is best in my opinion) so no change there for me.
    Jim
      E10 has been a thing in Oz for years.
      I run vpower 98 ron in the escos.
      You guys should be aware that e10 stoich is close to 14:1. That means all those crappy tunes running injectors at 100% for 14.7:1 stoich fuel will be lean.
      My work ute chews about 20% more e10 than e0 and runs like crap, so I don't use e10 in that either.
      John
        Just get the map checked for dett and fuelling and then you will know.
          Esso now do 99 octane too.
          www.sunnysidebb.co.uk
            I went to get some to try the other week, as I saw it being reported as being ethanol free. It wasn't - E5 like the rest, according to the pump, and the most expensive I've ever bought - way dearer than v-Power (Which is what I'll be sticking to.)
            Jim
              Bummer . I wonder if Mark has use the Esso stuff tuning?
                I think the bigger problem with E10 (or indeed E-anything!) is what it does to plastics and rubbers in the fuel system. Our cars are old enough to have materials that weren't specifically resistant to ethanol attack, I worry.
                Jim
                  More problems in store....mind you a I really only use Shell vpower. Mark has a second layer map on me emtron for 95 crappie fuel but It wouldn't be in the tank long.
                  Perhaps a full fuel line change to Aeroquip would resolve the issue?
                    Not sure that if we do have such a problem, that it won't take a bit more than that....
                    Jim
                      The nylon fuel lines are ok with E10. The in tank rubber lines and tank breather joiner rubber pieces are best updated to newer spec E compatible hose.
                      John
