Originally posted by AJC
View Post
Down On Power :-(
Yeah.......... just putting the kettle onOriginally posted by bigpower View Postany news J
can't get the friggin' bumper off
one bolt stopping it........... the front one you just have to loosen on the offside is stuck....... and typically it's the worst one to get at, just got the washer bottle off to see if that gives better access to get a spanner on it
Tea first though
....................... and a Hob Nob
You should get yourself to sunny South Wales Jules,Originally posted by spiritof'76 View PostNot convinced that it is but will know more later when i pull the bumper off............... if it ever stops bloody raining
as guess what........... its SUNNY
Hope you find your leak though fella
Bumpers off
.................. amazing what you can do with a Hob Non inside ya
............ and found boost leak
Inlet manifold gasket, fine on top but pissing out of the bottom, once the oily stuff was wiped away the fairy liquid showed it up no probs
I'm guessing it's one of these paper ones i've read about so probs best to relace with one of the Klinger ones that Mike does
but typically i think he's on holiday or summat
so a bit stuck as to where else i can get one................
Glad you found the definate cause JOriginally posted by spiritof'76 View PostBumpers off
Theres nothing worse than not knowing for certain the cause of a fault,
as that just rubbing salt in the wound
Yep, glad it wasn't my imaginationOriginally posted by cosmo View PostGlad you found the definate cause J
In the absense of Mr Rainbird i guess the next best bet would be Cometic gaskets.............. anyone know where i can get those in a hurry
........... Burton maybe, off to search their site now
I got mine from BurtonsOriginally posted by spiritof'76 View PostYep, glad it wasn't my imagination
Originally posted by bullett View Postmine doesnt run an inlet gasket
its been ringed
are you talking about where the inlet meets the head ? The gasket that's gone on mine is the one between the two halves of the RS500 8 Inj. Inlet....... rectangular thing with ten holes
Edit: Plenum is probably the word i am looking for
Yep, just got back from Burton with oneOriginally posted by cosmo View Post
Cometic then J
Dave, my pitcrew
, popped round last night and got me started and gave me a few pointers so now it's just down to me to finish getting it apart and stick the new one in
Looks a bit fiddly but no more than some of the gas boilers i work on so fingers crossed
if you see a huge fireball coming from the Essex direction later you'll know it's not gone well....................
