Originally posted by COZZFATHER
View Post
Down On Power :-(
O ringsOriginally posted by j1mbo View PostStrange. Is there no o Rings in there with the sealer ??
Keep us up to date
still not sure we are both talking about the same thing
are you on about where the inlet meets the head ? Because that's not what i've been doing............ i've cracked the plenum in half........ so basicly seperated the bit with the 4 additional injectors on in half
no o rings here, just one big rectangular compressed card gasket
Would have got it finished had the heavens not opened up
Here's a pic stolen off DK
Realisticly should i expect this plenum to be 100% airtight
just pumped it up again and can still hear bloody hissing
no so bad now, but still............
only bubbles i can see at the moment is where a little line from the fuel pressure reg. joins it............ only a little plastic connection, not sure if it's threaded or push fit
Tightened in the little plastic bit mentioned before............ no more bubbles. Did wonder if the hissing was just the air passing through the throttle butterly...........
Test drive done........... but still not convinced all the horses are at home
after all that
I guess as Mark says.......... RR............ Only way to really be sure
