mk motorsports alloy front hubs
  • Originally posted by c20tbo View Post
    So how many for a group buy and price? id be interested if the price is right
    HI ROBERT
    i will look at doing this again ,i will work price out for 10 buyers ,would you want camber adjustable like rieger shocks more expensive or fixed as standard
    mark
    • Id say just direct replacement mark as i also run the adjustable billet TCA's
      • I be interested in this
        • Hi mark,
          Id be intrested in them also for the tca you provided...
          Fizz
          • I would say they be about
            £450/£480 a pair
            • That sounds reasonable.
              • [QUOTE=c20tbo;625568]That sounds reasonable.
                It is mate lot of work lol
                Bolt on steering arms etc like wrc ones , can build in good roll centre from lowering
                And good ackerman in steering arms plus lots light reducing unsprung weight
                Thanks mark
                • Hello Mark,
                  Been thinking about these to fix the front rc on mine. So I'm keen for a set, but have a few q's.
                  Do these accept the abs sensor ?
                  You mentioned camber adjustable, what's the cost implication ?
                  Not familiar with reiger, what means of camber adjustment do they have ?
                  Do the oem tca and steering ball joints bolt up to the kit ?
                  What bearing options do these run ?
                  What grade of alloy and temper is used in them ?
                  John
                  • Originally posted by jsa View Post
                    Hello Mark,
                    Do these accept the abs sensor ? Yes
                    You mentioned camber adjustable, what's the cost implication ? About £150 extra
                    Not familiar with reiger, what means of camber adjustment do they have ? Camber washers
                    Do the oem tca and steering ball joints bolt up to the kit ? Tca yes best with rose jointed steering joints
                    So height can be adjusted
                    What bearing options do these run ? Standard
                    7075
                    • How long will they take to manufacture Mark? once 10 are down, i could do with a pair like yesterday
                        shouldnt be too long robert i already did some outline drawings from before ,if we get a few to get on list i would order material to do 10 pairs and sell the rest as and when
                        mark
                        • Interested ! Cash a bit thin on the ground at the moment but will have a pair at some point if your'e going to keep some on the shelf or can give a deposit to hold a set until things pick up
                          • Originally posted by MK Motorsport View Post
                            mark
                            Get a list started then Mark in traders section
                              hi robert
                              you start it here put your name on list lol
                              mark
                              • Ok
                                1 C20tbo
