Has it ben tested in the uk ? we broke our first one last week.
News on opliger box?
This is hard english:but the syncro "thing" has come of the first gear.dont know the accurate name for it here.
This is the problem with all these MT75 based gear kits which use the standard ratios. The speed disparity between the gears is too big, so with big power cars that accelerate so quickly, you end up always beating the syncros trying to match the gearchange with the speed of acceleration. The syncros then bur over, and once that happens the change gets progressively worse.
The ONLY cure is to change gear S-L-O-W-L-Y or move to a gear kit with better ratios (such as Fixit* or the new DP Motorsport like in Spirit's car) or dog engagement.
*Even these can be beating if changing gear too aggressively though.Mike Rainbird
Drove mine the 275m to and from ND no bother . Three people in car and we had no problem conversing. However, check my resto thread for the prep work for this .Mike Rainbird
Originally posted by warrenpenalver View PostI guess you have to heel and toe for all down changes??Mike Rainbird
Originally posted by Mike Rainbird View PostNope. Drive normally at slow speed. The issue is noise, I SAID THE ISSUE IS NOISE, DID YOU HEAR ME, I SAID THE ISSUE IS THE NOISE . Hence all the sound deadening in my car. It is now no louder than the Fixit was (inside the car).
I cant actually wait
Its a trolley ...its a shopping trolley (you know, with the spastic front wheel!!)
Fastest FWD Ford - 11.7 @129mph (183.99mph Topspeed)
the problem isnt the syncro it self its the syncro thing that is together whit the gear thats has come lose fron the gear and broke.
