10J rears with 6 degree beams..........
  • #46
    what put me off the 10 inch rears, was the centre where it bolts to the wheel hub, in some pics it deep like in the 9 inch wheels and in other,s like the one above it is quite shallow, i think it is something to do with the offsett of the wheel. I remember the three different sizes were ET20, ET25 and ET30 on Kelvs, Screemin, YUM and Reylands. All had 10 inch on the rear at one point. All with different ET,s. Not a big thing i know just didnt quite look right.
    • #47
      i think people are getting confused with the wheels
      if using coilovers there either et25 or et20 carnt remember what mine are, but with these offsets you dont need to mod the arm but you do need to widen the outer arch and mod the inner arch
      if you using shocks and springs you have an et30 as you can go in that much more due to having a thinner shock, but becuase the wheel sits in more you have to mod the inner arch and the trailing arm but not the outer arch
      with the pics ive seen of the adjustable beam on the arm legs its only the inner one that is modded, the outer leg is standard, so you should be able to run these wheels on et with an adjustable beam, alls you have to do is grind the lip that sticks out in the middle of the arm flush to give clearence for wheel
      regardless how the the arm adjusts, it will not adjust the wheel angle to the arm
      what im concenred about is having it done then when you adjust the arm it puts the wheel out towards the outer arch but it should still clear as it wont move it out by 20mm or more surely
      • #48
        A 10" ET30 has 23mm LESS inner clearance than a 9" ET20 (as well as sticks out 3mm MORE).
        A 10" ET25 has 18mm LESS inner clearance than a 9" ET20 (as well as sticks out 8mm MORE).
        It is the angle of how the modded arms mount to the beam that causes the arm to stick out a bit further...
        9" FTW .
        • #49
          ET Fookin phone home will you
          http://<span style="font-size:20px">...g.co.uk</span>
          • #50
            • #51
              Quality
              • #52
                Pmsl Dave
                Low Slung Denim.
                • #53
                  What does ET mean (in regards to wheels ) not Aliens.
                  • #54
                    And dont get me started on back spacing.
                    • #55
                      I gotta get my posts up to 1500.
                      • #56
                        who,d of thought that that extra inch would cause so much pain.
                        • #57
                          ET = "Einpresstiefe" or it's literal translation "press depth".
                          • #58
                            How much Press Depth do you get Mike
                            • #59
                              Depends who it is - you, about 2" if I'm lucky .
