Rear view mirror!!
    We use the oe Ford one, on any car we change windscreen on, ho have this kind of mirror.
    It`s the only one ho last for ever
      hi ill bring you some pads to ford fair, tip clean the mirror base well,rough the face slightly then heat it with a lighter,clean the black burning off then stick the mirror on......it wont move again.
      also dont heat the pad,heat the mirror base
        also if you glue them on,if your screen ever gets replaced they may not be able to refit the mirror properly and it will fall off again later.
          Not Suitable For The Use On Following Cars:
          •Seat
          •Ford
          •Mazda 121
            Originally posted by Adamski View Post
            Save me looking then, can you get me 1? also say 10 of the white clips that push into the sills thats you screw the hex screws into and 10 screws????
            pm me if you need to or if you need me to contact you on the main number!?
            give me a bell monday or pm me...had 8 cans now and will forget
            www.carpartsexpress.co.uk
              •Seat
              •Ford
              •Mazda 121
              ive used them on escorts before,wonder why that is?
                it will work,but if the mirror is a pad fitting mirror the metal is a different metal,i think it is pourus metal its soft. the way to make them stick is to heat the metal,they wont fall off then.
                  Just get a pukka mirror pad from Ford Adam.
                  Green side goes against the screen.
                    Only 8 cans u pussy.....
                      Adamski,
                      The guy next door fits windscreens so i'll ask him for a couple of pads and post them to you
                      Scouse.
                      • #26
                        The foam pad i had from the motor factors was green one side black the other but as said was gash! It insults me!
