What dump valves are people running holding high boost? I split the diaphram in my original since then iv tried 3 different kinds iv me n mates have had laying around but there all leaking on full boost
What dump valve???
I have Bailey dual piston recirculating on mine - I don't like hearing my car sneeze.
Yep.
Originally posted by B13 JUS View PostIt's not wastegate chatter mate, it's turbo stall, not healthy for a turbo.
As Justin said its the air passing back over the turbine blades cutting the air that makes the chirp noise.
But I agree i run no dump valve at all with a big k+n as I love the sound
Originally posted by psygnosis View PostDo you have any running problems running the DV ive heard that it feels like the car is going to cut out and then comes back in again.
Whats your take on it all ?Cheers
Originally posted by TREVCOS View PostYes, I have to say mine is just the same as yours mate, basically at idle when you hit the throttle and let it off the revs seem to dip too low then come back up again. I guess the Small Turbo isn't really built for an 'open to air' dump valve, it should dump back into the system and that's probably what the management is looking for. I did think about taking mine off and might at some point, but I just like it myself. I think in theory the twin piston valve is supposed to solve these problems but it doesn't really. My other small turbo was exactly the same.
