Stack dash install let me see yours
    John thanks mate - stunning car that Dave yeah i will be the gineu pig (sp)
    Mike i forgot about oil temp as well , as for fuel level i have tank in boot that dosent have a sensor its just a clear pipe you can see the level
    KJC thanks mate
      Can get the fuel level sensor for your tank I would think Carlo and tap the sump for the oil temp.
        Dave fook tapping the sump i will do it if the engine ever comes out its just a steel sump thats on it not a rs2000 one & yes its the same one you have
          John,
          That looks awesome - any more pics?
            Don't tap the sump, get a sump plug take off for the sender, I've done this on the MG and it works perfectly
            http://www.merlinmotorsport.co.uk/p1...duct_info.html
              ben thanks mate that will do the trick i will find out what thread is on the sump plug
                Going back to your fuel sender Carlo, does the stack have its own calibration so you can use whatever is in the car already (if you had one) or do you need to get a stack replacement sender?
                  Not sure mate i will have to take a look at my tank to see if there is anything in place blanked off for a level sensor but to be honest i wont use the car much so i will most likley just stil £20 in it every time i use it but would be nice to have it working all the same
                    The former. Providing the sender works off the normal 0-5v from full to empty, then the Stack can be calibrated to suit - you just divide the tank capacity by 10 and then fill it up in those increments telling the stack what each ready amounts to capacity wise. Once programmed, it then knows what to display by the voltage figure sent to the gauge and can extrapolate between the two figures so it ends up pretty accurate (if done correctly).
                      Cheers Mike a bit more research is needed then to see whether my sender outputs that range, I suppose what also may hamper me is that the wiring goes through a voltage stabilizer first
                      • #26
                        Originally posted by Mike Rainbird View Post
                        John,
                        as you wish rup!
                        got to love the carbon mike! think its been dyno'd at 215bhp
                        xflow way to go!
                        • #27
                          Wow.
                          • #28
                            That mk2 puts mine to shame stuning Audrey dash arrived
                            • #29
                              Gaz's
                              • #30
                                Old mans race car with Wilson m sport dash
