Bailey 3 port breathers advice oil return
  • Bailey 3 port breathers advice oil return
    What do you guys do for the oil return to the sump , have a boss welded into the sump or is there something you can do with the drain plug maybe a banjo type connection .......Cheers Rashers
    I have a Bailey system on mine and the oil drain goes in the block just above the sump below the turbo, if i remember correctly there is blank you remove
      Remove your oe kidney, an mount a nipple for breathing there, then you got the oe return to sump, under oil level
        as said this system is designed to use the blanking plug under the turbo the angled one NOT the straight one which is water!
        it is better to run the drain to the sump I modded mine to do this
        steve
        NSSCC 2016 Class B1 Champion
          steve
          lol first time i ever done one years ago i got the water 1
          1/4 mile 9.52 @ 146mph so far
            me too thats why I know!! lol
            got water/antifreeze in my eye..
            steve
              On the bailey you have two breather inlets at the top one goes to the blanking plug under the turbo the other one goes to where the kidney box was ,,,,,on the bottom of the breather there is two outlets a large one that vents to atmosphere and a smaller outlet which is the oil return where do you guys plumb this one to is it meant to go beneath the oil level in the sump if so do I need to weld a boss on my sump or is there another place to locate it cheers .......Rashers
                on the baily breather the top 2 are the breather so one goes to the kidney box the other to the cam cover the large vent on the bottom just goes down to atmosphere under the car
                the small drain goes to the blanking plug under the turbo
                this isn't ideal as you really want the oil to drain back under the oil level but to do that you need to weld an adapter onto the bottom of the sump
                steve
                  As i said over here, use the oe return to sump, and remove kidney. Then you got return to under oil level. The rest is as you say
                    steve
                    As long as it is 4x4 sump, then you got the return from under kidney, you don`t have to weld anything
                      I kept my original kidney piece so I have that return to the sump aswell
                      steve
