Part No
  • Part No
    Can anyone find out what the ford part numbers (Finis No) are for the front wheel hubs. Just the flange part which the wheel studs are located.
    cant help with the part numbers paul,but they wont be cheap,it would be cheaper to buy s/hand complete hubs and remove the flanges,my granada flanges cost aound £150 each from fords a couple of yrs back so id imagine they would be a similar price
      I think I have found some new hubs but I want to confirm the part number before I buy them.
        I'd check it for you Paul, but have Windows 7 on board and I am M1crocat less since
          Thanks. hopefully someone else may have it up and running.
            I'm sure number is: GAY4X4IS4BUMMERS
              Finis code found from iknowidriveaKAbutistillpeestandingup...honest.com lol
                Yeah correct
                You obviously wee sat down like the bitch you are
                  Will look tomorrow for you and FYI MCat works on Win7 😉
                  Scouse.
                    Originally posted by Scouse View Post
                    Will look tomorrow for you and FYI MCat works on Win7 ��
                    Scouse.
                    Thanks mate.
                      6930353 and 6930354 come up as the plain hub or in ford speak Knuckle, Front Wheel RH (and LH) respectively.
                      The wheel bolt face / hub are 6779654 03/1992 to 01/1995.
                      Hope that helps?
                        i may have some paul
                          Hope that helps?
                          Thanks Mark. I have ordered some brand new ones. They are listed as fitting the Escos and are cheap at £54 for the pair.
                          If they don't fit I will just return them and get a refund.
                          You can still get them from Ford at a £191.00 each.
                            i have a sneaky suspicion the ones that turn up will be wrong and have no hole for th drive shaft or somat daft but hopefully im wrong
                              Well Mark you were right.
                              It was all looking good everything fitted until I went to slip it on the splines. The hole and splines are too big so a rattling good fit.
