Can anyone find out what the ford part numbers (Finis No) are for the front wheel hubs. Just the flange part which the wheel studs are located.
Part No
Originally posted by Richie View PostI'm sure number is: GAY4X4IS4BUMMERS
Originally posted by Tarmac Terrorist View PostFinis code found from iknowidriveaKAbutistillpeestandingup...honest.com
lol
Thanks mate.Originally posted by Scouse View PostWill look tomorrow for you and FYI MCat works on Win7
Scouse.
ThanksOriginally posted by rs2kmk5 View Post6930353 and 6930354 come up as the plain hub or in ford speak Knuckle, Front Wheel RH (and LH) respectively.
The wheel bolt face / hub are 6779654 03/1992 to 01/1995.
Hope that helps?
Thanks Mark. I have ordered some brand new ones. They are listed as fitting the Escos and are cheap at £54 for the pair.Originally posted by Mark Barber View Posti may have some paul
If they don't fit I will just return them and get a refund.
You can still get them from Ford at a £191.00 each.
Well Mark you were right.Originally posted by Mark Barber View Posti have a sneaky suspicion the ones that turn up will be wrong and have no hole for th drive shaft or somat daft but hopefully im wrong
It was all looking good everything fitted until I went to slip it on the splines. The hole and splines are too big so a rattling good fit.
