Neil i think the rears are pretty strong from standard. The fronts are not lol
Front Diff Strengthening Plate
Originally posted by bullett View Postdan, i know this is for the front diff but do they not do them for the rear?i would have thought they would need them too?.
Originally posted by Mike Rainbird View PostYou thought wrong.
) that i should worry about. i will check to see if it has the plate but will that still put up with abuse or does it need going stronger.
the bloke who built my box mentioned a tremex diff as being tough enough for anything but ive never heard of themsigpic
save your money, a guy called cossiemandan *EDITED NAME THANKS WILL* uses a std diff with steel plate and it does a 10 second 1/4 mile with lots of power, lots of others have the steel plate with no bother too.
Thick fancy cover plate fandangos are a waste of money (unless your into shiny shit and want to pay through the nose for it)...no offence mike but a steel plate & std cover is as good if not better than your cover is it not? just doesn't look as nice as your effort
Dan
you wont be worrying rear diffs unless you are over 400BHP, in which case your best cheap upgrade (as I have done to mine) is just to stick in a 2wd rear beam and 7.5" Diff (ratios are near enough idential to the 4x4 one so interchangeable) with 108mm flange drive shafts... Front diffs are a bit of a lottery, but apparently the plate makes them a lot better, but again a thickwall one over 350BHP is advisable IMHO... Then its the gearbox, front shafts etc etc
Originally posted by bullett View Postits meant to be 430ish, has a quaife big tooth box,alcon 6 paddle, and grp n front and rear diffs.
how the hell did bill do a 10 sec pass?he was only 450 ish werent he?
Wil can you remove the original quote to stop the confusion over the name plz...
I think with a strengthening plate you'll be fine, obviously a lot depends how you drive, but for the money and the extra piece of mind its worth it even on a std car IMO.
Dan
Originally posted by sillyfezzamk1 View Postsave your money, a guy called cossiemandan *EDITED NAME THANKS WILL* uses a std diff with steel plate and it does a 10 second 1/4 mile with lots of power, lots of others have the steel plate with no bother too.
Dan. The extra oil capacity helps keep the front diffs cooler on track, so hardly a waste of money
If you saw what happened to my gearbox and diff casing when the front prop let go, the only thing that was holding the diff together was the cover.
I think that prooves its strength, as this was a Quaife thickwall casing. In fact the strengthening plate was undamaged is now living on Franco's diff
dont you think the diff may have exploded as your cover flexed too much? If the casing didnt flex so much why did it crackif it was the prop failure starting the destruction off then it has no relevance to the strength discussion.
You could quite easily use a steel plate and mod the std cover with the capacity for 1/2 litres more oilquite easily and for a lot cheaper.
Not having a go mike, I just like to look at things realistically when spending money, others choose not to but thats their choice
Dan
1. Of course he does.
2. The flailing prop took out the diff, the gearbox (a hole you could put your head through), it also smashed the clutch so that it was locked solid
As to saying that this doesn't show the strength of it is a bit bizarre, when the shock wave took out the casing in such a manner that is typical of the CWP climbing over each other and splitting the casing (there is no physical damage to the diff). However, it was so severe that the thick-wall casing could not prevent it either.Mike Rainbird
Originally posted by RWD_cossie_wil View PostYipes... Just be glad it didnt take your feet off at the same time
... Was that at the ring? what sort of load/gear was the car under at the time just out of interest?
7500rpm in 4th gear on the way back from Central Day last year!Mike Rainbird
