So who's running a gt30 on there escos
  • So who's running a gt30 on there escos
    Hi all hope you have all had a great Xmas.
    Looking like I am going down the gt30 roads but what do u lads that s got them think to them, can your buy a proper fitting fit or will that have to be made can t be bothered with the messing about lol
    1x escort rs cosworth imperial blue
    1x mk2 focus rs frozen white
    1x fiesta rs turbo mercury grey
    focus rs mk1 sold but never forgotten
    Spk to cossiedavid mate he will sort you out... I used to run a gt30 on a 14 inlet cam and ported head and was a great setup
      As Iain says great set up, mines running 482bhp on standard manifolds on a gt3071
      Cossiedavid will sort you out with 1 from cr turbos,
      There's a wee bit of messing about to fit it on a 4x4 manifold but worth it ! I prefer the standard exhaust manifold set up,
      CheeRS Shaun,
      SCS MAPPED 482 BHP 400 lb ft
        Cheers mate what u running now then
          What is needed to do to mani mate
            Nothing to the manifold, the turbo just needs spun and the head of 1 of the bolts shaved, its not too bad of a job, reyland done the mods to fit 4x4 manifold on my turbo, but I helped my mate do his that he got from Cossie david,
            CheeRS Shaun,
              Glad I went GT30 tbh. Lazy off boost and a bit laggy but it's low comp and could pro be down to cam timing aswell. No probs though get it going and it's awesome lol
                Mines ain't lazy or laggy, and that was before mapped properly on that turbo
                CheeRS Shaun,
                  I have used a GT30 for over three years.
                  With the correct engine spec and mapper (Mark Shead) it's a very good turbo.
                  Some info here:
                  http://passionford.com/forum/general...es-514bhp.html
                    Some info here:
                    And even at 7.2.1 comp it still gos like a missile
                      What comp are you building your engines to now usually?
                      CheeRS Shaun,
                        7.8.1 to std built dugs back when low comp was the in thing
                          Ok mate, crazy how things change, and now most people don't go low comp now
                          CheeRS Shaun,
                            Sounds good lads what spec is your turbo Shaun
                              Gt3071r mate with 72 exhaust housing
