Twin scroll manifold with 7064 and alternator issue
  • Twin scroll manifold with 7064 and alternator issue
    Hi Gents, for those of you with twin scroll manifolds and an EFR, what have you done about the alternaor?
    it's very close and possibly will fowl on the manifold once it's belted up and tensioned.
    drop bracket?
      Drop bracket mate
        As in RS500 style? i thought that but didn't want to butcher my block
          hi andy
          i think anembo do an all in one bracket that you dont have to cut the lug off block
          mark
            Andy,
            Yes Anembo do a bracket that no cutting is needed, i'll be ordering one, where did you get your alt?
            http://anembo-engineering.mybigcomme...nodised-black/
              can you get longer belt?
                A drop bracket isn't enough, I had to mill the mounting holes on the cast alternator bracket also even then it's very tight. Best thing is to change over to the later type belt as u can pull the alternator away from manifold then.
                  Any pics of the other setup, will that need the serpentine belt? was there not a cosworth that run the alt under the inlet manifold? poss 3dr
                    Anembo it is then!
                    thank you chaps,
                    Leigh, i'll try it and if theres still a problem i'll have to work round it
                    Rob, it's actually from Euro Car parts
                      Wheres the resto thread,, that engine looks
                        I've not bothered doing one, i will do one for the rebuild
                          Is it the escort? Hows the saph coming along
                            what i meant was this engine looks like a 2wd engine with the old belt set up, the later set up as fitted to all escorts with the different tensioner allows the alternator to be pulled down away from the manifold with a small bracket to hold it there. the other alternative is a group a set up but these are very hard to come by.
                              That's what mine has
