Twin scroll manifold with 7064 and alternator issue
Andy,
Yes Anembo do a bracket that no cutting is needed, i'll be ordering one, where did you get your alt?
http://anembo-engineering.mybigcomme...nodised-black/
Any pics of the other setup, will that need the serpentine belt? was there not a cosworth that run the alt under the inlet manifold? poss 3drOriginally posted by lee2cossies View PostA drop bracket isn't enough, I had to mill the mounting holes on the cast alternator bracket also even then it's very tight. Best thing is to change over to the later type belt as u can pull the alternator away from manifold then.
what i meant was this engine looks like a 2wd engine with the old belt set up, the later set up as fitted to all escorts with the different tensioner allows the alternator to be pulled down away from the manifold with a small bracket to hold it there. the other alternative is a group a set up but these are very hard to come by.Originally posted by c20tbo View PostAny pics of the other setup, will that need the serpentine belt? was there not a cosworth that run the alt under the inlet manifold? poss 3dr
