I hope you're sitting down, as I have priced this up to do in Aeroquippe and including the T-piece for the twin pump arrangement, you're looking at £400
This is for the hose from the in-tank pump to the filter, the hose from the filter to the swirl pot, the twin hose to single hose converter from the two fuel pumps, the hose from this to the FPR and then the return to the swirl pot and the swirl pot to the fuel tank return.
Obviously if it was a single pump set up, this would reduce significantly (£60), as then you wouldn't need the 2 into 1 adapter, which is required with the two pump set up.
The swirl pot is £200 for twin pumps and £190 for single.
.This is for the hose from the in-tank pump to the filter, the hose from the filter to the swirl pot, the twin hose to single hose converter from the two fuel pumps, the hose from this to the FPR and then the return to the swirl pot and the swirl pot to the fuel tank return.
. If you don't want in aeroquippe, I could do just the tanks no probs
