suspension people
  • Originally posted by cossymad View Post
    The collar you refer to is suposed to be a few mm above the hub carrire. You should not elongate the hole!!
    Any proof for saying this Chris?
    • Originally posted by Mike Rainbird View Post
      It will lower it to the point that it should be, as they should SHOULD be flush with the hub, as per the photos showing this on this thread .
      Is that 100% as cossy mads says the oppersite???
      • Originally posted by bigpower View Post
        Common sense tells me that the weight of the car should be on the swaged collar and not the pinch bolt
        • The more i bloody read the more im confussed
          Dont want to do it tomorrow and find ive done wrong but in my head i think so too
          Ive mailed Ahmed to ask for his opinion as his springs are made to mate with Konis....
          Mike, you didnt fully commit today ( saying be carefull what you take out etc ), is theyre any reason for that? As you say above they SHOULD sit in the hub fully to the shoulder?
          • they look well high karl,maybe they just welded the tabs on too low down
            • Originally posted by cosmo View Post
              you can see the difference in width at the shoulder before the shocker narrors again, so im guessing thats where the strength is if it sits with the shoulder higher, then im guessing its straining on a narrow/weaker part that should be passed the hub, hence kinking them if cornering hard/ backroad driving etc
              Im no mechanic but minds fooked
              • Take out as much as is needed to get the strut to sit on the SHOULDER
                • look forward to some knowledgable peoples opinions today before i get elongating
                    I've been an engineer for 33 years with I'd say 27 years of that working for the automotive market, so I guess it rules of out.
                      I'm with you Paul
                      A little unfair Karl, Paul has more engineering knowledge than most of us on this site put together
                      Or are you just after opinions from internet experts?
                      • Originally posted by The Radman View Post
                        yours is better kenny lol
                        Ahmed said yes you can elongate to make the car lower but leave about 5mm above the cv boot. I didn't get a definate of yes it should sit upto the shoulder or no the should sit above
                        What did you take out? Looking at my pics with the measure, I'm thinking 8mm so it just sits on it?? When I took the pinch bolt out it went into the hub , more like 12mm.
                        • Originally posted by Monster View Post
                          I'm with you Paul
                          Dave, I didn't have a clue what Paul did for a living!
                          Paul, sorry pal, I didn't mean anything from thAt!
                          • AFAIR the welded collar that sits a few mm above the hub is there to stop the shock punching down through the hub should the bolt break. By allowing a few mm grace, should the bolt break the shock will only move that far down IF there is an issue, and you'll know about it i.e if it happened on track running a kerb for example.
                            Having the shock already restining or sitting on the hub puts unnecessary load on the top and not as it should be squeezed together and held in place.
                            I am looking for a picture to show this but photobucket is playing up :'(
                            I doubt it will make any difference overall, if it were me I would do it if I needed to, but as I have coil-overs, I don't.
                            You could modify spring cups or top mounts too, just get a geo check done afterwards.
                            phone > 07969 182540
                            • Chris I'm not doing it just for the sake of lowering the car. Yes I feel it sits abit higher than I thought it would but the more I've been reading into this, I want to do what's correct. Some say how it is , is the way it should be and some say sat on the collar is the right way???
                              I tried asking Ahmed what he thought as if he said sat flush, then obviously his spring drops would be from there but he stayed on the fence?? So I'm non the wiser ......
                              Very interesting but bloody confusing lol
                              • The reason I am being cautious is that Koni refused to comment one way or the other . With the location bolt where it is, they seem too high and with the pinch bolt removed, they seem too low to me, so I'd do them about half way.
