am i right in thinking that the backing plate needs to be cut to allow the new bracket to take the bolts? just trial fitted mine and this looks as if it must be cut unless i have bracket round wrong way. also the rubber flexi pipe from rear beam to the calliper seems pretty stretched now does these remain standard or is it advisible to fit slighty longer one? cheers.
fitting reyland 300mm rear discs
hi
I may be able to help here......
Heres how i cut mine so the 2 bolts could be accessed,these were brand new shields too! Remember to paint them after cutting or they'll soon rot!
Should then look like this when fitted
I know its been said on this thread by Kelv to fit the caliper at top and not towards the rear but i didnt have any problem and thats where mine are with the handbrake cable connection or the caliper piping.
From the back you can then get to the 2 bolts now
should look like this then to finish off
I know that Monster makes back plates so he would be able to help with these should you need some.
Mart
balls i just had my backing plates powder coated ,but thanks for pics great help what you you file or hole cutting tool on drillOriginally posted by redrsmk5 View Posthi
I know its been said on this thread by Kelv to fit caliper at top and not towards the rear but i didnt have any problem and thats where mine are with handbrake cable or caliper piping.
Mart
WounderOriginally posted by georgie1 View Postballs i just had my backing plates powder coated ,but thanks for pics great help what you you file or hole cutting tool on drill
these were cut in the drill with a hole tool then de-burred and filed down before final glass papering to make neat and tidy. Over kill i know but attention to detail from my Dad
Yep thats correct georgie, i hate seeing rust anywhere and this was a simple quick fix.Originally posted by georgie1 View Postthat where the disc rust i guess as rear pads dont touch there but could be wrong
Yes they are 300mm rears and fill the wheel nicely.
And yes Nick, Genuine cable mate, i was surprised it fitted but it did
