What options are there and what's the difference between bigger rads & slim fans on offer? They seem to vary a lot in price for what seems the same product.
Bigger rad & slim fans
There is nothing wrong with the standard set up on a lightly modded car (unless it is full of shit etc, where it just requires a flush through). Why do you want to change?
That is a good reasonOriginally posted by neverenough View PostThe pipe is rotten and the rad is on it's last legs. So if it's got to be replaced, might as well upgrade too. Plus even with a turbo cooler it's still a bit high on the temp side.
What temps do you see (if you say the needle is in such and such a position, I will reserve the right to laugh
You only need the slimline fans if you physically can't fit the OE ones, which is only normally the case with the 65mm intercooler AND 50mm radiator. If you have just the 50mm intercooler, you shouldn't need the slimline fans
You will need the slimline fans then. Depending on the ambients, I can't say if that is good or not. If in the 20s, that is to be expected. If in the mid teens, then I would expect 87-90°C.Originally posted by neverenough View PostMid 90's, sometimes more, low 90's on motorway.
I've got a A&H intercooler which I believe is 60mm can't remember 100% been in there a while, was looking to put a 60mm rad in also.
Personally, I would go with the AH radiator to match the intercooler.....Mike Rainbird
