Kev, You need to ctreate a folder on the C disk called FPM then copy the files into that folder and run it from there.
PC based Pectel Monitor Software - 100% FREE
Originally posted by mallard man View Postdemo mode now working. looking good. can it be modified to read more than 2bar manifold pressure.
There are a few chips configured to run the Bosch 5 bar (4.6 bar) sensor and if I ever get my hands on one of those, I will add it to the software.
Works great, thanks a lot, look forward to trying it. May seem a silly question, to anyone this is, where does this plug as I'm sure if I'll still have the diagnostic port you speak of, as my loom has been replaced. Is it the white rectangle 1 with 4 maybe 5 round connections in it, in a line in under the dash n/s?
Originally posted by SECS View PostYes provided the P8 has comms enabled in the chip and has the ECU has had the hardware modification needed to run it.
(just like you need for a standard original pectel monitor)
I have one of your older version secs monitor, is it possible to update it to the newer version whit shift light and bar reading??
Originally posted by neverenough View PostWorks great, thanks a lot, look forward to trying it. May seem a silly question, to anyone this is, where does this plug as I'm sure if I'll still have the diagnostic port you speak of, as my loom has been replaced. Is it the white rectangle 1 with 4 maybe 5 round connections in it, in a line in under the dash n/s?
The diagram I supplied above does show the ecu pin numbers.
Originally posted by grcossieWhat is actualy this modification, and do you do this??
All the times I have had access to one, I have forgotten to look..LOL
Originally posted by grcossieI have one of your older version secs monitor, is it possible to update it to the newer version whit shift light and bar reading??
