And so the Questions start.....
  • #46
    just a bit bored Ben lol,may need a change but more than likely i will still have the car and get back into it.
    • #47
      whats the spec nowadays dave was on a T4 last time we spoke... i know what you mean about getting bored but like i said unless you have bigbucks to get something exotic imo you will always come back to an escos its like an illness...
      • #48
        if it did sell i know i would be back Ben.
        different car now Ben, this a a t34 on blacks,around 400bhp.
        got the t4 engine,now over 500+ and Bara ,spec r cooler sitting here,just deciding if i want to put it in or not.
        • #49
          Jimbob, can you have a peek at the prices when you get chance.
          Ben, when are you expected to have the car in your possession and start work?
          • #50
            Kelvin, wrc inlet is 400 with fuel rail and our inlets are 550 that's with throttle cable bracket and powder coated
            • #51
              Defo chuck is in dave that will liven you up a bit sounds like you got the transmission sorted too
              Soon come @ Kelv
              which inlet is the WRC one out of interest?
              • #52
                I'm not sure either Ben.
                I want the same inlet plenum that Jacko has, and to run 8 injectors as my loom is catered for that already, plus I already have the 8 injectors.
                Jimbo, I'll be in contact
                • #53
                  Sorry to hijack the thread but what benefit is the st inlet over the large turbo one? Is it a worthwhile upgrade on a standard internal engine?
                  • #54
                    Flows a bit smoother and quicker due to the better shaped elbow which is less restrictive.
                    It would be a bit more responsive than a standard 4wd item on a mildly tuned engine.
                    Also has the potential to be able to flow enough air to cater for up to 600bhp iirc.
                    • #55
                      this one Ben
                      • #56
                        Paul, so which one is the WRC plenum cover?
                        I want the 8 injectors as you show above, but with Harvey's plenum.
                        • #57
                          Ben - this'll defo end up being another moneypit
                          I've managed to resist on mine thus far - although i've got a few goodies to go on stored up already.. Beam / koni's + 300mm rear brakes are next on my list.. - then hopefully she'll handle nicely, and i can think of a little more power...
                          • #58
                            if its on topic its all good
                            looks like ST/BT cover might go over it
                            Originally posted by cosmo View Post
                            this one Ben
                            nice one Cosmo CheeRS so can you answer me and kelvs question on what cover goes over it?
                            Hi Rolls how you doing good to see your still about you are 100% right but i have bugeted in my mind and im slowly getting things together and seeing what its costing and at the same time i am working out what i can get back for it when i break it
                            • #59
                              might aswell spend a bit of money Ben than have it in the back doing nothing.
                              • #60
                                lol @ what you can get back when you break it.. - always worth keeping any eye out for parts on here!!- some bargins to be had at times!!
