Hydraulic clutch conversion
    how much
    isnt the concentric clutch conversion better
    No george rubbish is cylinder leaks its box out and e30 bmw one sits on side spot on
      Originally posted by cossyking View Post
      Sorry mate been very busy its a sieres 2 or 3 i get part numbers tonight
      Thanks mate, gonna get the stuff ordered asap, any info on what rose joint to use and hose diameter, what fitting etc and pics would be great if you have any
        cheers m8 price on a full kit
          tbh, I would rather give it to someone and get the full conversion supplied and fitted.
          it does not cost that much imo, all the hassle gone then.
            Much more satisfaction doing things yourself
              true, though a lot more effort and maybe more money in the end.
                More money?
                  I can supply a kit for about £160
                    Could someone please explain the benefits of having a hydraulic clutch. I'm a bit thick
                      More money?
                      depends on what your time is worth.
                      • #26
                        Clutch will be lighter and if a paddle clutch is fitted takes alot of the harshness away when operating clutch
                        • #27
                          I've done mine and as Mark says it's one of the best Mods you can do to a Cossie
                          • #28
                            Mods like this are cool as they are subtle but bring the car abit upto date with modern driving.
                            Nothing worse than a heavy clutch when your used to driving a newish car
                            • #29
                              Anyone know which landrover master cylinder to use with the integral pot, is it a freelander one?
                              Originally posted by Sonic Boom View Post
                              Only if you have a fairly standard clutch or rather pressure plate, i've gone back to a side push after i've been through 3 centre push bearing in a year uprated covers just murder the bearing.
                              Rich
                              I ran a concentric for years with no bearing failure on an AP twin plate.
                              I will be running one on a triple plate this time. You must have had the wrong bearing or a crap concentric system.
                              • #30
                                I have to say I was using a bearing from a Mondeo which came with the kit and I just kept changing for the same part number.
                                I did look at fitting an uprated bearing the real nice ones were coming in at the 300 pound mark, so I just went back to side push and it works fine for me.
                                Rich
                                The Cossie isn't in the Garage because it's Broke, its because I am!
                                Speed Doesn't Kill, It's not being able to Stop in Time!
