That was one tiny kink?? Makes me want to get my Billies fitted ASAP, who knows how bent my billion year old konis are
suspension people
Originally posted by Paul RS View PostThat was one tiny kink?? Makes me want to get my Billies fitted ASAP, who knows how bent my billion year old konis are
Both my pics above are with the car on the same struts, and all that has been altered is the hole has been elongated in the Koni's NOTHING ELSE
The one with the Rondells in silver was taken almost 2 years ago and the one with the wheels in gold is from last summer.
Decided not to buy anymore Koni's, so I purchased GAZ for front and rear. So far all is well after 8/9 months. Gary told me that the steel they use IS thicker than on the Koni's.....and all is good so far. I know this beacuse I check my camber at least a couple of times a month with accurate home-mage guages.
Bonus is that the GAZ front struts and rear dampers have more adjustable settings (not just the soft/med/hard of the Koni's), it took a bit longer to find the optimum damper settings, but very good results in the end
Also with the GAZ you do not have to unbolt the rear damper to adjust it - so a lot easier adjust/fine tune, without even having to jack the car up.
Originally posted by L8 ECU View PostI've got 7 or 8 that are bent more than the "tiny kink" one shown (but not as bad as the other one in the top pic)......Once there is a kink (however slight) then it can only get worse over time, because it's a weak spot.
Originally posted by cosmo View PostGaz gold or just Gaz Doug
Contact Chris Flint (he posts on this forum)....
CARNOISSEUR SOUTHEND
763 London Road
Southend SS0 9SU
Tel: 01702 482 545
or BurtonPower.com on-line.
Fronts are GAZ 0103 (£ 89.00 each including VAT)
Rears are GAZ GT5-2066 (£ 49.95 each including VAT)
Compare those to Koni's prices.......Last edited by L8 ECU; 18-02-2010, 16:34:34.
Originally posted by L8 ECU View PostGAZ Shocks is what they are know as - see the Burton catalogue, or BurtonPower.com on-line.
What spring weights are you running on yours out of interest ?
Low Slung Denim.
Originally posted by Loader View PostGaz do two types, the std coilover and the gold coilover ( gold being chunky-er and more adjustable iirc)
The above combination when correctly set up is simply exquisite
Takes a fair bit of time to set up the damping (because of the large range of adjustment available) but IMO well worth the hassle.
