ABS Sensors
  • #31
    Straight fit to mine any way
    • #32
      Originally posted by James @ Auto Dynamix View Post
      I'm working on a supply
      • #33
        I recently had a front sensor on a 94' fail. I ended up using a early Sierra one (chopped the plug and soldered and heat shrunk escort plug on -resistance and voltage spot on-works perfectly 😀😉
        • #34
          might be able to use the rears from Scorpio too? some diffrent types here
          http://www.onlinecarparts.co.uk/spar...-ggr/4699.html
          • #35
            Photo's of the rear ABS Sensors
            [IMG][/IMG]
            [IMG][/IMG]
            • #36
              Originally posted by Darrenaf View Post
              My sensors looked like that, i cut out the alloy insert cleaned the corrosion and put it back together using liquid metal worked a treat .
              • #37
                its only where they connect to the car loom that are different
                but all granad scorpio frog eye shape use the same rear abs sensors as an escos, and at a guess fronts as well
                • #38
                  Cheers Darren, don't suppose you know the length of them?
                  • #39
                    31mm from end to end.
                    • #40
                      Think Ben will want cable length should be around 500-650mm?
                      • #41
                        sorry will have to get them out, where is the connector located is it under the rear seat?
                        • #42
                          yes
                          • #43
                            i will drop one out tomorrow and take some photo's/measurements
                            • #44
                              cheers mate. Lets see what happens but sent details for the fronts over so hopefully hear back soon
                              • #45
                                Got a response back he now wants the parts numbers for both front and rear sensors, can anyone help with that also?
