best choice for TRACK CONTROL ARMS
  • #46
    Originally posted by ablc View Post
    it's 4 or 4.1 cm 1.58 inch or 1.62 inch.
    If you are refering to the diameter of the arm in de ball joint area then I think it should be 46 mm. Standard Sierra’s have 41 mm, but my Cosworth is 46 mm.
    On the 46 mm arms I had the ball joint replaced by a spherical SKF bearing which can be replaced if it’s worn.
    '90 Cosworth 4x4
    '91 2.9 24v RWD Ghia
    • #47
      look
      • #48
        I wonder if someone like kinzy fabrications could machine new ball joints and fit them into the standard arms?
        • #49
          Should find the ball joint ?
          • #50
            Yes. I kept my old ones to do it.
            asked local company doing such things and they said they can do everything.
            • #51
              moog have small ball joint to.
              • #52
                hi,
                i need news TCA but radman said that aftermarket tca are poor quality !!!!
                Any idea if Combrake are always good guinine ford spec ?
                Any experience with Delphy or moog parts ? other ?
                Thank's
                I'm pretty sure I bought some of the Compbrake ones and they weren't the same.
                • #53
                  What do you guys recommend now?
                  • #54
                    Comp brake still really, most don’t have the same size ball joint but then again do any Cossie owners need to worry about wear these days? Most aren’t used to the extent the used to be due to value etc Just MOT mine other day and they’re still pretty good after 10 years. Will see how they continue after June Germany trip lol
                    • #55
                      Has anybody tried these.
                      https://anemboengineering.co.uk/cosw...justable-tcas/
                      • #56
                        • #57
                          They’re class, originally made by MK. Rose jointed on both sides so less likely to wear out as quickly as conventional ball joints. But price VS longevity of life, the comp brake still the more sensible option IMO
                          • #58
                            I got also comp brake ones..no issues at all
                            • #59
                              Originally posted by JohnP001 View Post
                              I had a set of these on order this time last year but ended up being refunded as they couldn’t get a single pair made - needed to be a batch. Ended up with compbrake ones
                              • #60
                                Any news for some good tca or compbrake is always thé Best option ?
